Customized Shaft Hoisting Technology
Mensajes apartados de otras secciones. SPAM, insultos, etc.
Cerrado
astao242
Moto: Fashion123
Mensaje por astao242 » Mié 19/02/20 15:11
Our company has more than ten years of production experience in this industry.
Skip and cage mechanical guide wheel are the key components to improve the stable and reliable operation of the container. Based on the existing shaft hoisting technology, our company has developed a mechanical guide wheel with symmetrical hollow structure support for skips and cages.
The wheel assembly of skip and cage mechanical guide wheel is composed of symmetrical hollow structure hub, bearing, polymer sealing assembly, polyurethane roller and so on. The symmetrical hollow structure hub reduces the weight of the roller ear, reduces the moment of inertia, and is more conducive to heat dissipation in the use of polyurethane roller and bearing; the polymer seal assembly is corrosion-resistant to mine water, has self-lubrication, and has no wear on the spindle in use, which makes the waterproof and dust-proof more reliable; the polyurethane roller has high elasticity, wear resistance, tear resistance, water resistance and water resistance. Oil resistance and other advantages, the use of the above parts to ensure the long life of the roller assembly.Customized Shaft Hoisting Technology
website:http://www.chinaymatom.com/shaft-hoisting-technology/
Cerrado
