electric water heater quotation
Mensajes apartados de otras secciones. SPAM, insultos, etc.
Cerrado
Lindajeon55
Moto: 345656777878798988
Mensaje por Lindajeon55 » Mar 07/04/20 09:06
Water heater
1. Configuration.
Length WidthHeightInner diameterSurface temperaturePower at 25℃ water
100 mm2025Φ10260℃80W
100 mm3835Φ20260℃200W
100 mm4039Φ25260℃280W
100 mm4745Φ32260℃340W
200 mm5047Φ35260℃500W
200 mm8179Φ65260℃800W
200 mm9290Φ76260℃1200W
200 mm110107Φ93260℃1500W
200 mm125122Φ108260℃1600W
200 mm135132Φ118260℃1800W
Various materials.
1) Aluminium shell or pipe, it is cheaper, but not good in resistance to corrosion.
2) Brass or copper shell or pipe, it is good in resistance to corrosion. But it costs higher.
3) Ceramic shell, it’s good in resistance to corrosion. But its heating power could not be very large.
4) Stainless steel or titanium shell or pipe, it is very excellence for preventing corrosion, and meets food safe standard. But it costs higher and has bigger bulk. China patent number: ZL 2011 2022 0811.4, ZL 2011 2022 0805.9.
5) Anti-corrosion coated aluminum shell, it is corrosion resistance, and prevent incrustant, but the cost is quite high.
2. Some samples of uses.
PTC water heater could be used for shower, footbath, washing hand, vegetable and dish, drink warmer and boiler, fermenter, tea warmer, coffee warmer, milk warmer, vapor generator, sauna bath.
They could be used in heating diesel oil, gasoline or other liquid. Using PTC as a heating element could prevent the oil burning, it’s safer.
3. Notice in appliance.
PTC as a heating element, it fits for high safety, slap-up product. In some situations, it’s low cost and convenient.
The electric power of PTC water heater changes with the temperature of water. The higher is the temperature of water, the smaller is the power.
Using higher switch temperature PTC can get higher power, 220~270℃switch temperature PTC is selected usually. But if select too high switch temperature, the reliable will reduce.
Power is almost same to change the voltage twice or decrease of 1/2. electric water heater quotation
website:http://www.tchqsz.com/ptc-thermistor/he ... nd-boiler/
Cerrado
